03 Monte Carlo SS Steering Column/ FRONT END COLLISION
Old Apr 3, 2012 | 01:40 PM
erosem21's Avatar
Default 03 Monte Carlo SS Steering Column/ FRONT END COLLISION
I had a front end collision in my 03 Monte Carlo SS last Sept. The air bags deployed, I replaced the hood, head lights, and bumper. The steering wheel is just duct taped shut and the light is on for the airbag on the dash. I found a steering column from a 00 monte carlo LS. will this work in replacement? or do I need to find another one.. or is there an easier way to make it pass inspection?
Your help is greatly appreciated!! THANK YOU!!!
Old Apr 3, 2012 | 01:50 PM
Budsjlm's Avatar
unless your colum is messed up you won't need to replace the whole colum, you just need to replace the airbag, airbag computer, and quiet posibly the seatbelts as they usually have a small charge of explosive that is activated the same time as airbags to keep them tight
after all that you may need to find someone with a rather expesive scan tool to reset the airbag light, small dealers that mainly deal with salvage cars should have one or be able to direct you in the right direction for a price i'm sure they would help you out
Old Apr 3, 2012 | 01:59 PM
erosem21's Avatar
yes that does help alot, I will definatley look into those parts. Thank you!
Old Apr 3, 2012 | 02:00 PM
Does your seat belts lock up when u pull em hard?
Old Apr 3, 2012 | 02:52 PM
erosem21's Avatar
yes they still lock up and work. I don't believe my seat air bags went off.
monte2001carlo
Jan 12, 2011 05:17 AM
teddy620_2000
Oct 9, 2007 06:15 PM
vincentvega
Sep 21, 2007 06:43 AM
krandall
Dec 16, 2006 07:24 AM
locs650
Oct 14, 2005 08:46 AM
