99 dash
Old Mar 19, 2009 | 09:46 PM
99ls's Avatar
Default 99 dash
hi I just bought a 99 ls and i have a pioneer headunit i would like to install but I cannot figure out how to take the bezel off to get to it can you help pictures would be awesome thanks
Old Apr 13, 2009 | 12:30 PM
bowtie8_3's Avatar
I would like to know this also.....
Old Apr 13, 2009 | 02:40 PM
The Popcorn King's Avatar
If in anything like my 97, then your going to have fun taking it off. But its not imposable.
After you remove the 2 screw on the bottom cover below the steering wheel. just pop off the dash bezel. its held on with clips. Now for the fun part. Tilt down your steering wheel to its lowest position and turn the ignition key to RUN. Put your car in LOW and start to wiggle (yes, i said WIGGLE) the dash from the left side first. It might need to be forced a bit, but once it passes that small compartment just below the light switch, it could come right on out.
To install, just do in reverse.
If you have anymore question, let me know and maybe tomorrow i will bring my camera with me to work and take it apart and take pics as i go along.
Let me know.
Old Apr 14, 2009 | 09:54 AM
99ls's Avatar
I have the gear selector on the floor i didnt have to put the car in low to get the dash apart it was a pain getting past the tilt lever on the column tho
Old Apr 14, 2009 | 12:39 PM
see, i told you you had to WIGGLE it.:p:p
Nitro40
Jan 26, 2011 02:36 AM
mickey
Sep 27, 2006 07:10 PM
JMonte
Sep 7, 2005 05:38 PM
the4thlast1
Apr 26, 2005 08:41 PM
krazy92rs
Apr 5, 2005 04:35 AM
