98 monte carlo 3.1 help
Old May 8, 2010 | 09:12 PM
carolinafan4life63's Avatar
Default 98 monte carlo 3.1 help
Hey guys , I need some help with the vacuum lines on my 98 Monte.
there are two on the upper intake , one on the drivers side front and one on the passengers side rear that I have no no idea where they go to. i just installed a used engine and for the life of me cannot find where these two lines go. any one happen to know or have an idea??or possibly have a diagram showing the routing for the vacuum hose on this car? thanks in advance for any help you may be able to give me.
John
Old May 9, 2010 | 03:16 PM
seawolf18's Avatar
This will hopefully help out.
(1)To EVAP Canister (At Rear of Vehicle)
(2)EVAP Vacuum Switch
(3)EVAP Canister Purge Valve
(4)To Rocker Arm Cover
(5)Air Intake Duct
(6)Throttle Body
(7)PCV Valve
(8)Fuel Pressure Regulator
(9)To Transaxle
(10)Intake Manifold
(11)To Accessory
(12)To Vacuum Brake Booster
(13)MAP Sensor
jaydflash
Aug 29, 2014 03:38 AM
team monte carlo ss
Aug 11, 2008 06:02 PM
cj702
Aug 20, 2006 03:20 AM
