'97 monte w/ 3.1 and coolant issues
Old Oct 11, 2005 | 11:54 PM
mayerichm's Avatar
Default '97 monte w/ 3.1 and coolant issues
Okay, I searched and didn't find what I am looking for. My temp gauge will go above normal then come back down. But if I have my heater on when the needle goes up it will still be blowing cool air and then it will warm up when the needle comes down. The oil looks good but I took it to a shop that said I need to replace an intake gasket. But if it's not in the oil or on the ground, where is it? Can it leak into the intake and the catylitic converter is burning up the smoke? WTF???
thanks for any help
Old Oct 26, 2005 | 10:45 PM
z34phoenix's Avatar
Default RE: '97 monte w/ 3.1 and coolant issues
if your lower intake manifold is leaking, you could be getting coolent flowing into your intake and burning in the engine. i would also check the radiator, i had a small crack in mine near the upper retrun that i fixed with jb weld. it was so small that you would never see coolent on the ground but i would leak enough to notice.
Old Oct 28, 2005 | 05:32 PM
Patrick's Avatar
the 3100s are great for having intake manifold leaks and bad water pumps.
Old Mar 3, 2006 | 11:16 AM
desighitter's Avatar
Yep, my 97 Monte had both. Bad intake gasket and water pump failure. My coolant was leaking into the oil. In addition, belt tensioner went out. Not unusual for these engines. Still a good engine though.
tjmaples
Dec 15, 2010 09:44 AM
00MCLS
Nov 27, 2010 01:01 AM
tarfin
Nov 21, 2009 01:17 PM
revealingdarknes
Jul 29, 2009 07:06 PM
GTown
Nov 11, 2005 11:27 PM
