96' rear wheel (suspension? hub?)
Old Apr 23, 2012 | 06:34 PM
zillatattoo's Avatar
Default 96' rear wheel (suspension? hub?)
Hello all. my monte is still running like a champ. Despite my crazy cheating Ex slamming her ****ty aztek into my rear Q-panel. Other wise I do have a question. My driverside rear wheel has some east-west play in it. (The psyco hit the other side so it not from that and it had been doing it before our "accident") I can pull on the top of the tire and it pulls out an inch or 2 and makes a clunking sound.When I look under it and someone pulls it the whole thing moves...as in the drum, and please excuse my lack of total knowledge but..the bottom of the strut and stabilizer links/bars?,...well where it all comes together behind the hub, it all moves with the tire. I havent found any loose nuts. So I raised the back end up off the ground and then it doesnt pull out or have any play in it. It also produces a clunking sound from back there when I hit a bump. Yes the lugs are tight...any help appreciated.
Old Apr 23, 2012 | 07:34 PM
nitehawkjcb's Avatar
Either a strut issue with the clunking going over bumps, check the wheel bearing bolts
Old Apr 23, 2012 | 08:49 PM
zzapultimate's Avatar
Sounds like you need a new strut. Get that fixed asap.
Old May 9, 2012 | 05:48 PM
thanks for the responses...sorry for the late thanks. Gonna get new struts for the back new shocks ball joints tie rods/TR ends for the front and Im in the process of repairing the quarter panel.Got it pulled out about 90% of where I need it to be to start grinding off the paint and just got 6 cans of torch red off amazon. have to get new tires too.
Old May 9, 2012 | 06:40 PM
Sounds like you have a nice project! Post some pics if you can
Old May 10, 2012 | 10:24 AM
Make sure you mark where the tie rods are (or count how many turns it takes to get them off) otherwise your car will pull to one side like a chump
Radagast the White
Aug 17, 2014 10:52 AM
2002 SS
Mar 10, 2014 09:21 AM
bittyx2
Dec 12, 2013 08:33 AM
shad420w
Jun 7, 2011 03:13 PM
stealthregal
May 8, 2008 11:02 AM
