95 Monte Carlo, jerks and slows down, FIXED
Old 09-14-2014 | 03:39 PM
volkerc's Avatar
Default 95 Monte Carlo, jerks and slows down, FIXED
For all of you that might encounter the following symptoms:
-car drives fine for a while with no problems, all of a suddens starts to sputter,feels sluggish, no accelaration until you floor it
-making left or right turns, coming out of the turn car acts the same as above...
Drop your tranny pan of your 4t60e and inspect the accumulator pipes!
The pipe that has a rubber hose in between the two ends had come out of the housing causing the above symptoms. After going through the engine, the gas tank, fuel pump, that was it!
Unbelievable but true, pressed it back in, works. Runs.
I know I read of these problems before, so if your out of ideas like I was...do the above.
Old 09-14-2014 | 03:48 PM
Thanks for the heads up!
Old 09-15-2014 | 08:48 AM
Monte Of The Month -- May 2015
Monte Of The Month -- March 2017
Thanks for the Great Information, It always helps when you are out there at the mercy of the mystery of repairs.
Old 11-18-2014 | 05:49 PM
moore47's Avatar
Thanks, will try this weekend. Just posted about the same problems.
Sadmonteowner
07-30-2015 02:30 PM
cimber
04-26-2012 12:00 PM
Franks 03SS
01-20-2012 11:50 PM
Scooby doo
12-12-2011 12:06 PM
04 Intimidator
09-15-2007 02:24 PM
