88 monte carlo- heating coil
Old Aug 25, 2012 | 10:16 PM
finksta33's Avatar
Default 88 monte carlo- heating coil
So,
I am buying a sick 88 ss and the only main problem is the "heating coil" starting leaking. So the air conditioning and heat aren't working-they blow just not cold-or hot.
Just seeking enlightenment and possible estimates for this works?
Thanks!
Old Aug 26, 2012 | 05:16 AM
Hi Finksta,
Is your Monte Stock or is there modifications ?
I hope that we have a member that can help or give you some idea on cost to repair, but it's difficult to give a answer with limited infor. A bad thermostat can cause your stated problem. Have you searched on the MCF Search Engine or web for same or similar problems with your make/model ?
Look forward to see your new to you Monte...
Good Luck ..
Old Aug 26, 2012 | 10:12 AM
finksta33's Avatar
It is pretty much stock except for an edelbrock carb and air filter.
But i'm not too familiar with this specific part. It is right on the top left end on the engine compartment (basically right where the ac module is on the dash) but the piece has been removed (it was leaking) the seller claims you DONT have to remove the dash for this work.
wvmontels
Dec 30, 2013 07:57 PM
oneandonlydylawn
Jun 2, 2013 02:15 PM
Joe Bloggs
Dec 2, 2009 09:55 AM
connersdad19
May 29, 2009 03:24 AM
