86 Monte Carlo LS HELP
I have my 86 and i wanna upgrade engine parts but don't know where to start and looking for parts was annoying because i couldn't find parts(all 5.0 v8). is a 4.3 v6 worth fixing up such as headers/exhaust/pulleys etc.??? please any help with be appreciated. What advice do you have for me to do to my 86 LS
Welcome to the MCFTell us about your Monte ? How is the condition of your engine now ? How many miles on your engine ? What is your modification budget ?
How much power to you want ? Expect ?
Check the below links & also check back to see what our member's post with their experience with the 4.3L > Good Luck & we look forward to your future posts
- General Motors 90° V6 engine - Wikipedia, the free encyclopedia
en.wikipedia.org/wiki/General_Motors_90°_V6_engine
Jump to 4.3L (262 CID) - The 4.3L (262 cid) V6 is the last and most successful engine in ...model year, the 4.3L had its block design modified to allow a ...3.3L (200 CID) - 3.8L (229 CID) - 4.3L (262 CID) - See also
- Making Big Horsepower With A 4.3L Chevy V-6 - Hot Rod Magazine
www.hotrod.com › Pit Stop
A production 4.3L V6-90 is a true even-fire engine. Achieving even firing pulses in a V-6engine with a 90-degree cylinder-bank angle required GM to offset the ...
- Chevy 4.3L 262ci V-6 - Engine Build - Overview - Tech - Hot Rod ...
www.hotrod.com › Technical › Hot Rod Engines
We build a Chevy 4.3L 262ci V-6 using V8 parts and technologies. ... 113 0208 V6 00 Z ...Dougan's was able to modify Milodon 190,000-psi rod bolts for a 350 ..... ....as well gmmakes a 4.3 vortec natural gas industrial engine that has a factory ...
- GM Goodwrench 4.3L 262ci V6 Engine - JEGS
www.jegs.com/p/Chevrolet-Performance/GM...43L...V6-Engine/.../-1
Free Shipping! For 1993-95 and 1999-2002 GM 1/2-ton applications, the remanufactured4.3L 262 engine is a 2-bolt main block with 1-piece nodular iron ...
- How to build a 200-300 hp chevy 4.3liter v6 on a serious budget ...
answers.yahoo.com › ... › Other - Cars & Transportation
Oct 12, 2008 - Heres my round up i have chevy 4.3 liter v6 that came out of a 1993 s10. i ...and a 48mm twin bore throttle body from the 5.7 L GM Small-Block engine. ... [1] Both trucks featured sport modifications to the standard suspensions.
It depends what your end goal is, but keep in mind, cars of your Monte's generation were not commonly modded back then. As a result, most any mod you would consider doing will probably require a lot of custom fabricating. But if you want to stay with a v6 and put the time/effort into it, you could end up with something unique and awesome. Just look at the Grand National, a turbo charged 3.8L v6 and it surprised a lot of people I think in it's day!!
If you are looking for cheap and powerful, switching to a Chevy 350 is a great way to go. It's a common engine, lots of aftermarket stuff and just the engine swap along and you'll have a ton more power.
Food for thought.
BTW - Share some pics of your car and projects!! We love pics here.
And Welcome to MCF!!
Food for thought.
I went from a 305 to a stock 350 out of a truck and couldn't believe how much better it ran. I found an old chevy truck wrecked for 300 bucks and took the motor out and put right in place of the 305. Of course, with a throttle body 4.3 car, you can put in a throttle body 350 and leave it fuel injected easier than if you were starting with a carbureted car. You already have the gas tank/fuel sending unit, gas lines and all the wiring for fuel injection. That would be the easiest way to gain a lot of horsepower in your 86. V6's can be modded but try looking for parts for late 80's to early 90's model 4.3 S-10. They're a little more common and the engine parts should interchange. I'm not 100% sure they interchange but it's something you could check out.
nothing is really wrong with the engine besides a little tune up to change worn parts. i have 98x,xxx miles on it. i am on a tight budget being a student but can spend about 4-600 a month on parts. i dont care much about power i just wanna make sure my engine is healthy and running without any problems, i want to keep this car forever thats why i want better parts rather than stock.
How much does it usaully cost to change to a 350 engine? i am having problems finding part most are for the 5.0 v8 and wasnt sure if it is worth investing in my 6. this is what my MC looks like now. THANKS IN ADVANCE!!
https://sphotos-b-sjc.xx.fbcdn.net/h...87899578_n.jpg
That's a nice teaser pic of your Monte.
BTW - I meant to say (and did not say), v6 engines of your year were not commonly modded.
As for parts, if you want better then the run of the mill parts sold at the corner stores, you can try performance shops, like Summit Racing. Honestly, I don't know what the cost to drop a v8 would cost. But if you are considering a 350, it does not have to be from your year Monte (which GM I don't think ever put in). Just look for a Chevy 350.
