6th gen Monte Carlo, whats the best way to replace cut battery terminal
Old Nov 19, 2025 | 01:23 AM
myfurstcar's Avatar
Default 6th gen Monte Carlo, whats the best way to replace cut battery terminal
Title says it all, I had some issues with the battery terminal wires, and i cut them trying to use one of those battery terminal replacement kits, the copper wire inside the terminal seems impossible to feed into the replacement part. Not sure what to do now, ive been stuck on this for a couple of months, coming back every so often to see what i could do. I'm considering replacing the whole cable, but that would probably be difficult and time-consuming. Any thoughts?
Old Nov 19, 2025 | 05:31 AM
craig32's Avatar
Replacing the whole cable isn't a big deal. The positive cable goes to the starter, fairly straight-forward and accessible, and the negative cable probably goes to the engine block, it may have a smaller wire going elsewhere - even still, it will just be a small bolt. We must not be buying the same cable ends, the ones I get the cable lays in a recess, and a strap bolts over the top - nothing really to feed into.
Old Nov 19, 2025 | 11:41 AM
myfurstcar's Avatar
could you link the cable replacements youre using? the ones i have are a pain to install
Old Nov 20, 2025 | 06:27 AM
craig32's Avatar
2005lt3.8
Jul 17, 2024 12:38 PM
24_48Fan
Aug 31, 2010 11:54 AM
thorspower
Aug 26, 2007 01:37 PM
Laserblue06ss
Jun 8, 2007 11:17 AM
BeachBumMike
Feb 4, 2007 01:28 PM
