4th Gen. Shifter Identifying
Old Dec 29, 2014 | 08:28 PM
DerrtyD's Avatar
Default 4th Gen. Shifter Identifying
real quick and a simple yes or no will do..
in the 4th gens, are there 3 speed and 4 speed shifters? if yes, is there a clip that will change a 3 to a 4?
Old Dec 29, 2014 | 08:41 PM
yes, there are 3 and 4 speed aftermarket shifters. Not sure about stock shifters. 3 or 4 speed is determined by the transmission and not the shifter.
Old Dec 29, 2014 | 09:55 PM
claydoh's Avatar
If Im not mistaken, 84 montes had the r700 trans the ss was a H.O. engine with a three speed and the rest had a 4 speed w/ overdrive???
Old Dec 30, 2014 | 07:40 AM
Some general Info:
The Novak Guide to the
GM TH700R4 / 4L60 & Early 4L60-E Automatic Transmission
The TH700R4 is an automatic shift, four-speed overdrive, longitudinally positioned transmission. It is now considered to be one of the finest overdrive automatic transmissions ever produced.
History
The Turbo 700 was introduced in 1982 as a response to fuel economy pressures, and to be phased in as the replacement for the TH350. The transmission was available for both car (RWD) and truck platforms. The transmission's principal new feature was its 30% overdrive. It also sported a lower-than-usual 3.06:1 first gear, popular for off-the-line acceleration as well as off-road torque.
There were some initial bugs in the earlier versions. A feather in GM / Hydramatic's cap was the fact that they stuck with the 700R and followed through with improvements and upgrades. 1987 and newer transmissions are considered to be refined and very reliable, as indicated by their OEM installations against performance 350 V8s in sports cars and trucks. Earlier transmissions are affordably given all these upgrades to put them at the same high level of durable service and performance. Aftermarket building techniques and parts upgrades make this transmission very capable of Big Block power in race, street and off-road applications.
In 1990, the 700R4 was redesignated as the 4L60 (4-speeds, Longitudinally positioned, 6000 lbs. GVW). This was a change in name only with no significant mechanical changes associated.
The 700R4 and Mileage Benefits
A good part of GM's reasoning in developing the 700R was to allow more of their vehicles to meet ever stricter mileage and emissions requirements. It was an effective strategy.
By converting to the 700R, your Jeep may realize significant mileage benefits as well. It is not uncommon for swappers of this transmission to see a 30% drop in fuel consumption if the Jeep sees highway use.
Additionally, the transmission features a lock-up torque converter to allow a direct, non-slip connection through the transmission. This has the benefit of further fuel savings and cooler transmission operating temperatures. However, it is crucial that this lockup mechanism be properly connected to the ECM and brake lamp circuit. Stand-alone computers are available on the aftermarket for its control. Some control units even allow for the lockup to occur at a given speed. Lock-up converters in automatic transmissions give the advantage of direct engine lockup through the otherwise fluid-coupled transmission. This function works either by the ECM or a vacuum switch. Earlier versions without ECM use a vacuum switch connected to ported vacuum. The transmission receives the signal and applies fluid pressure to the clutches in the lock-up converter. The system switches off due to a signal from the brake pedal.
If you run the transmission with the converter unlocked all the time it will run a little hotter. Keeping it cool is important. The advantage of this lock-up converter is increased fuel economy and decreased heat at cruising speeds.
If you would like to simplify the stock setups, torque converter controls are available through racing supply retailers in a variety of styles. These facilitate the proper installation of the TH350 and 700R4. The on-road advantages are obvious. For the off-roader, the ability to manually switch the torque converter on is excellent in that it allows for compression braking.
In 1993, an important change did occur and that was the conversion of the hydraulic logic shifting system over to an electronic one. Mechanically, the transmission's power transmitting core remained the same, but the valve body and actuation system for the clutches, bands, etc. became controlled by electronic actuators and solenoids. A Vehicle Speed Sensor (VSS) was used as the primary feedback sensor, which fed the PCM or ECM (vehicle powertrain computer) the data to make shift decisions. The engineering of this system is not regarded as a complication, but an elegant simplification and further improvement to this transmission. This version is called the 4L60-E (or Early 4L60-E for our purposes).
In 1997, the 4L60-E began to be released having received a redesigned case. This is the Later 4L60-E, discussed here.
Identification
The 700 transmission has a main case of cast aluminum alloy with a length of 23-3/8" long. It is distinguished from the TH350 and TH400 in that it has a square oil pan, lacking the distinctive cut-off corner of the TH350 and the "Texas" shaped oil pan under the TH400.
Versions of the 700 transmission prior to 1984 had a 27 spline input shaft, changing later for a 30 spline input shaft. The transmission typically has a 1/4" pipe fittings on the passenger side for a cooling circuit. Later versions use a pinned flare and o-ring design for these fluid circuits.
The key distinction of the 700R4 / 4L60 / Early 4L60-E (from the Later 4L60-E) is the four bolt rear output or tailhousing / adapter pattern. The Later 4L60-E has a six bolt "hex" rear bolt pattern and a removable bellhousing.
There are three main castings of the 700R case. One is the standard car version. Another is cast slightly thicker, designated as the "K" case, as purposed for many trucks. The occurance of case breakage is very uncommon and most individuals swapping the 700R-4 into a Jeep probably will not be benefitted by one over the other. A third, rarer version was the "60 degree" version, as discussed below.
Two-wheel-drive versions have a tailhousing and typically a longer output shaft. Four-wheel-drive versions have various adapter assemblies and a shorter output shaft. If the tailhousing is removed, electronic versions can be distinguished by the absence of a worm drive
Old Jan 1, 2015 | 10:12 PM
claydoh's Avatar
I had, briefly a '84 Monte SS in anniversary blue that said H.O. with a 3 speed 700 R4 tranny, my "87 had a 4 speed 700R4 with overdrive??
Old Jan 2, 2015 | 07:19 AM
DerrtyD's Avatar
thank you all for your answers but i think H317 got it answered. I was mainly asking about the stock shifter. I know the cutlasses could swap a clip
DerrtyD
Dec 29, 2014 08:16 PM
kelso
Nov 18, 2012 05:17 PM
Enzo354
Jan 16, 2012 08:54 AM
Rick ICS
Jun 4, 2010 10:36 PM
YamahaR14
Apr 21, 2008 06:53 PM
