4t80e Monte Wont Start
Old Feb 16, 2020 | 02:48 PM
WolvenScout's Avatar
Default 4t80e Monte Wont Start
Welp, I got everything important wired in, and the 4t80e swapped car wont start. Its not the battery, cause I'm using the one out of my daily. I had to extend some of the small guage wires to the starter, and relocate some ground wires. When I tried to crank the engine without the fuel pump relay in order to cycle the water pump, oil pump, and trans, nothing happens. When I turn the key to ON, all the dash lights come on, and my trans controller lights up, but the starter wont do anything. Does the PCM have to have a signal from the trans to know its in park/nuetral so it'll start?
Old Feb 16, 2020 | 04:27 PM
Okay, a bit of a jump on my part. I completely neglected the external neutral safety switch on the 4t80e. I can jump the starter (crank) relay, but I'm having trouble getting it to idle.
64GunMech
Apr 14, 2017 02:32 PM
LetsGoPeay
Feb 19, 2014 07:08 AM
drmusicmaster
Apr 9, 2013 05:20 PM
glewisr
Dec 15, 2010 11:02 PM
SpaceAce
Dec 22, 2009 12:19 PM
