6th Gen ('00-'05): 3800 SS power fluctuates uphill
Old Sep 21, 2019 | 09:03 AM
ltrain's Avatar
Default 3800 SS power fluctuates uphill
Just got an 05 Tony Stewert MC. When going uphill w/cruise on, the power fluctuates. It idles smooth and does well on level surfaces. The original owner did say it needs a tune-up. Any idea?
Old Sep 21, 2019 | 06:18 PM
xpage's Avatar
lacking fuel or air would be my guess. Check fuel pressure to make sure it's not low. Cheapest routes are replace fuel filter, clean MAF, clean fuel injectors, replace cat.
Does it struggle when going uphill when you floor it on flat terrain?
Old Oct 13, 2019 | 12:49 AM
Chevy_fadez's Avatar
Does it?
Old Oct 20, 2019 | 12:50 PM
ltrain's Avatar
no. it seems to have no problem when the ss kicks in. Maybe ss compensates for an intake problem. Any sensor for that?
Old Dec 7, 2019 | 03:38 PM
ltrain's Avatar
PCV was not installed. A stuck open pcv valve will cause "surges" I found out. The idiot left the spring out so now I guess I start searching junk yards. Do ya think it's the same size spring (sc or non sc)?
wht02monte
Oct 15, 2019 07:21 AM
redbug2
Sep 21, 2015 07:41 AM
04 SS/SC
May 3, 2015 09:03 PM
S1knes
Jan 13, 2014 05:34 PM
jgargano03
May 15, 2009 09:56 PM
