350 vs 454
Old Nov 24, 2010 | 12:33 PM
1970monte454's Avatar
Default 350 vs 454
does anyone know the length difference of a 350 block to a 454 block.i looked for a few days and cant find anything other then the weight difference..for some reason google mistakes length for weight..but i was talking to my dad about the swap and he mentioned my drive line wont work, and that ill have to buy one or get mine shortend.well, my response to that was ill just suck the motor forward more, he gave me a funny look and chuckled.so im looking at the difference's in lengths so i can start running numbers and measuring.thanks for any info gals/guys.have a fun t-day and xmas.i got snow pics ill get them up soon
Old Nov 24, 2010 | 04:20 PM
BigKev's Avatar
You should be able to move the mounts to fit the 454 in...my 85 monte fit a 402 BBC....multiple mount locations....
Old Nov 25, 2010 | 06:36 AM
sideways's Avatar
Yep , the trans stays where its at . The mounts are on the block in different locations to compensate. the only time you would need a different driveshaft is if your useing a different trans.
Old Nov 26, 2010 | 10:09 PM
Justin Knight's Avatar
yep either will fit easily you could fit 2 350's end to end in there if the fan and rad are taken out probably. not that anyone should think that it is a good idea to try. look on youtube for the '70 cummins monte carlo. that is a long engine and pretty cool what the guy did.
87SS_builder
Aug 29, 2013 02:20 AM
Kracktheskye
Feb 5, 2011 02:55 PM
The Beep
Apr 12, 2008 01:54 AM
Fiky206
18
Sep 30, 2007 08:11 PM
sixty4
Feb 3, 2006 08:31 PM
