3.5 2006 Monte Water Pump
Old Jan 3, 2010 | 04:32 PM
slinkeey's Avatar
Default 3.5 2006 Monte Water Pump
What kind of job am I looking at to replace this?
On my old Grand Am (2.4l), the thing was driven off of the timing chain so it was a real treat.
I know the Monte is driven off of the serpentine belt.. I can can see that much.. IT has just been too damn cold to get a real good look.
Jeff
Old Jan 4, 2010 | 04:58 PM
seawolf18's Avatar
Water pump is pretty easy. Take the belt off and drain the coolant. Unbolt the water pump from the block. Make sure all the old gasket material is removed. Bolt the new pump on and refill to coolant. The pump does not run on the timing chain like the quad 4 or lt1 engines.
augle27
Mar 14, 2011 01:42 PM
sportjunkee
Jan 13, 2008 07:13 PM
Brooke
Oct 17, 2007 04:35 PM
montejass
Apr 25, 2005 10:48 PM
