3.1 litre water pump removal (1998)
Old Sep 29, 2013 | 03:12 PM
Gbrown's Avatar
Default 3.1 litre water pump removal (1998)
Howdy all,
I might have to change out the water pump on my 98 monte.
Question, do I have to remove the power steering pump to get to all the bolts on the water pump. Some say yes other say no. What do ya'll say?
Thanks
G
Old Sep 29, 2013 | 05:20 PM
zzapultimate's Avatar
No you don't have to remove the power steering pump. I believe all you have to do is remove the belt, and then you can get to the water pump pretty easily. It's one of the easiest things to change on that engine.
Old Sep 30, 2013 | 10:00 AM
Gbrown's Avatar
Default water pump
Thanks,
As I looked closer at the pics it looks like the complete pump is contained behind the pulley, should be a snap.
Old Oct 17, 2013 | 01:19 AM
grknss's Avatar
Originally Posted by Gbrown
Thanks,
It is the easiest water pump I've ever had to change, I did my 98 a couple of months ago. the bleeder screws help "burp" the cooling system easy as pie!
Gbrown
May 11, 2014 08:44 PM
shynativegrl
Jul 4, 2011 11:30 AM
Brooke
Oct 17, 2007 04:35 PM
PCWeber
Mar 11, 2007 10:58 PM
jogasz28
14
Oct 30, 2006 11:01 PM
