2007 Monte Haynes Manual Question?
Old Dec 8, 2007 | 01:05 AM
Twisted_Metal's Avatar
5 Year Member1 Year Member
Default 2007 Monte Haynes Manual Question?
Does anyone have the Haynes Manual for the 2007 Monte Carlo V6 3.5L. I want to remove my front rotors and have them inspected for warping and I want to replace my front brakes, and do a oil change tomorrow. I wanted to see if I could have a diagram of what to expect. I've done brakes before on two other cars one a Mercury Station Wagon, and the other a Mazda 626LX and oil change, but I want to do it by the book with my new car.
Old Dec 8, 2007 | 03:43 AM
Default RE: 2007 Monte Haynes Manual Question?
ahh nevermind they haven't made 2007 Monte Carlo book yet ...
Old Dec 8, 2007 | 03:36 PM
[:@] Well I almost had the rotars off, but then I noticed this isn't like a Ford..[:'(]
Damn, if I would of known the rotars were fastened to the axle I would of never took anything apart ...
I think I need a 25mm Socket to remove the center piece just to remove the rotar. I don't recall having to do this on my Ford wagon. I need a manual ...
I would hate to pay the dealer $45 for finding the problem and another $450 for parts and labor just to turn a frikin' rotar or replace it ... why are cars so difficult ...
Anyhow I'm still puzzled as to why my car pulsates at speeds over 80mph when I apply the brakes to slow down, but doesn't do so at slower speeds. Could the rotars be warped to a small degree where I isn't affecting the brake pads? Or is it just a heat issue with these cars and these type rotars?
This car was a used rental car with 15,000 miles on the O/D when purchased ...
The big nut in the center has to go before the rotar will free up? Ford is a little different where as the nut thingy stays on the car while the rotar moves freely .... well atleast that's how i remember when I had to have my Mercury Rotar replaced after a score from worn
brakes ..
The brakes look good (the same for the other side too no problems) why is my car pulsating when I brake?
Old Dec 8, 2007 | 03:43 PM
I'll check the rear brakes tomorrow, but i'm most certain it's coming from the front end ....
Old Dec 8, 2007 | 03:50 PM
2000LS's Avatar
why check for warping? either you have a brake pulsation or you dont... if you have a brake pulsation and a shimmy in the steering wheel only when braking, then the front rotors are warped
btw, you would need a dail indicator to check lateral run out. and a brake micrometer to check thickness variation
Old Dec 8, 2007 | 03:54 PM
Well the initial check was to make sure my brake pads weren't damaged ...
Old Dec 8, 2007 | 11:40 PM
alltak's Avatar
I do not have a 2007 manual, but on a 2005, the rotor should come off after the caliper andbrackets come off. There is no need to take off the nut.
Old Dec 8, 2007 | 11:45 PM
That's what I thought, but it's all one piece .... I need a 20-25mm socket and some leverage to move that nut ...
Old Dec 9, 2007 | 03:07 PM
2000LS's Avatar
i'm not positive on the size, but think that big nut that you do not need to take off is going to be a 34 or 36mm
i'm guessing whats stopping you is that small black torx head bolt that holds the rotor against the hub
Old Dec 9, 2007 | 04:31 PM
Hmmm, I was wondering about that tamper torx screw ... I'll try again next weekend ..
