2006 Monte Struts
Old Jan 23, 2014 | 06:20 PM
Good to know about the AGX/Canuck pairing.
For the heck of it, below are a few pictures of the lowering setups I've done to both Monte Carlos I have owned; my prior 03 SS and current 06 SS. Both have been a very decent ride quality in my opinion. Also, to note, I would highly recommend all new strut mounts. Upper and lower insulators are swapped over to the new assemblies from the old factory strut assemblies. Let us know if you have any further questions.
This is the Bilstein HD/Canuck setup I'm currently running on my 2006 SS. Here's my thread for this project > https://montecarloforum.com/forum/ti...istress-37750/.
And this is the KYB AGX/Eibach setup I ran on my prior 2003 SS.
Old Jan 23, 2014 | 08:11 PM
Overkill's Avatar
Matt, your new struts match the colour of your old Monte
Old Jan 23, 2014 | 08:39 PM
xxtheshockerxx's Avatar
RED DEVIL
Originally Posted by Overkill
If you ordered the KYB AGX 734058/59, they'll fit and you'll love em with Canuk/SSC springs, good ride quality.
Rockauto carries the AGX struts.
good to hear they are a good pairing. I have been looking for a cheaper alternative than the Bilstiens when the time comes
Old Jan 23, 2014 | 09:35 PM
boggie's Avatar
have a 2001 SS it is stock have a cid and a custom exhaust put kyb plus shocks on front not happy with them I also found out that the shock you pick has alot to do with the suspension package that came with the car. if you look at the SPI [service part identification] or also known as RPO which is located on the trunk lid it will tell which suspension you have.Your car could have 1 of 3 FE1 is soft ride, FE2 system, ride , handling or FE3 sport so this has some impact on which shock to chose good luck
Old Jan 23, 2014 | 10:17 PM
The FE3 is the Impala SS suspension package and the FE4 is the Monte Carlo SS suspension package. They're the same architecture and boast beefier components for the Super Sport package over the base suspension packages for both cars; FE1 being the base Impala suspension package and FE2 the base Monte Carlo suspension package.
Regarding the Monte Carlo, the FE4's struts are tuned differently for a firmer ride, better handling and control over the FE2 package.
Old Jan 24, 2014 | 06:27 AM
Overkill's Avatar
Boggie, did you get the KYB GR2s? Very different than the KYB AGX struts
Old Jan 24, 2014 | 06:58 AM
That's literally what I was thinking, and they are completely different. I see the GR2 as being more of a comparable factory replacement and, obviously, the AGX as a sportier upgrade.
Old Feb 3, 2014 | 01:00 PM
gregaplummer's Avatar
Old Feb 3, 2014 | 02:35 PM
Nice, that looks good and sits just right. After you get some miles on it, let us know your thoughts on the ride quality with the setup you went with.
Old Feb 3, 2014 | 04:15 PM
Hiroska's Avatar
Nice size rims, what are those, 18s? Looks a bit smaller in tire width..20s?
