6th Gen ('00-'05): Gearshift stuck in Neutral/Drive
Old 07-01-2021, 07:31 PM
Dizzy920's Avatar
Default Gearshift stuck in Neutral/Drive
I daily drive an '05 with the 3400. Today I was moving the car to mow. I shifted in reverse and then pulled forward to park it. It will not shift in to Reverse, Park, or even my low gears. The button on the shifter will not depress completely and I can't move it otherwise. Any ideas what I should look for? Or if anybody knows exactly what's up that helps too. Really hoping that it's a fix that I can do myself because I can't quite afford to have it taken to a shop.
Old 07-02-2021, 08:42 AM
Monte Of The Month -- May 2015
Monte Of The Month -- March 2017
You will need to remove the shift handle and then the console section to see what is up in there. Most likley that area is dirty and sticky, also the shift plate inside the console is a plastic material and may have a broken or cracked piece.
Zap-o-matic
10-08-2016 06:50 PM
Jeremy Klein
07-07-2016 11:43 AM
06mistreSS
05-11-2013 07:41 PM
Gbrown
09-18-2009 01:33 PM
RickCoMatic
01-23-2008 10:01 PM
Quick Reply: 6th Gen ('00-'05): Gearshift stuck in Neutral/Drive
