2006 Monte Carlo SS Horn Troubles
Old Dec 12, 2015 | 06:37 PM
chris2006SS's Avatar
Default 2006 Monte Carlo SS Horn Troubles
Hello. I'm new to the forum here. As the title says, I have a '06 SS. I'm having trouble with the horn. It started several months ago when I heard a change in loudness of the horn. It became muffled. A few weeks ago it began 'sputtering' when I would use it until it finally made a sound like it burned out. It hasn't worked since. I'm wondering if any members here have had similar problems and what they would suggest? I've read a few places to check the relay but haven't been able to find it anywhere. Does this model even have one? Thanks for any help!
Old Dec 12, 2015 | 09:41 PM
Did you check the horns because I had the horns on my 2005 monte & the horns on my wife's 2005 Impala ss go bad.
Old Aug 20, 2016 | 08:06 PM
Default Fixed
Turns out both of the horns went bad. One took awhile to follow the other. There are two different horns to this setup, a high note and low note. This is indicated by a letter on the plastic horn body itself. Both of them new off of eBay cost about $70 together. The connectors in the replacements are no good though, they don't fit. You'll have to buy your own, which is expensive, or make your own. I was able to get the connectors from Carquest for about $6. Just a couple wire cuts, splices, crimps, solder, and you'll be good to go. Feel free to post or message any questions. Thanks!
