2006 Monte Carlo charing issues
I know you was trying to help obviously but most people when testing the charging systwm start thw engine and have it running while they are checking things out. Do you hve anymore real advice for me.
The only time I have seen that is if I was in heavy rain and went through a big puddle, I would lose power steering and get the charging system notification. After a few seconds it would go away but only happened in the rain. I taped & loomed a bunch of wires and haven't had that problem. You pressure wash the engine bay by chance? Maybe a wire broke somewhere or got loose (alternator). Just crawl around and check everything electrical. Make sure your fuse box is clean, no water residue inside. Your battery should say 12 volts when the car is off and 13 to 14 when running, meaning the alternator is charging the battery. But check the voltage when you start the car and see if the voltage dips below 9, that means the battery is getting weak. I really think its a rogue wire somewhere.
The belt could be slipping. I've also had a new alternator be bad right out of the box before, so don't rule that out. Certainly check for corrosion on your battery cables, alternator cables, and fuses.
7th Gen ('06-'07): 2006 Monte SS electrical gremlins
twinswin91
02-02-2013 10:08 AM
