2006 Monte Carlo charing issues
Old Jun 8, 2022 | 09:09 PM
Jman1234's Avatar
Default 2006 Monte Carlo charing issues
I have a 2006 Monte Carlo 3.5l, I've replaced the alternator, battery, starter, ignition switch, cleaned all the connections and my meter still reads 12.17 volts. What am I missing?
Old Jun 9, 2022 | 10:34 AM
nitehawkjcb's Avatar
Not trying to be funny, but that's a normal reading if the car is not running.
Old Jun 9, 2022 | 11:11 AM
Is there any other issue or problems?
Old Jun 11, 2022 | 07:21 AM
Jman1234's Avatar
I know you was trying to help obviously but most people when testing the charging systwm start thw engine and have it running while they are checking things out. Do you hve anymore real advice for me.
Old Jun 11, 2022 | 07:23 AM
Jman1234's Avatar
Their are no other issues, car runs fine starts fine, no idiot lights...other than service charing system.
Old Jun 11, 2022 | 05:50 PM
JTBell's Avatar
The only time I have seen that is if I was in heavy rain and went through a big puddle, I would lose power steering and get the charging system notification. After a few seconds it would go away but only happened in the rain. I taped & loomed a bunch of wires and haven't had that problem. You pressure wash the engine bay by chance? Maybe a wire broke somewhere or got loose (alternator). Just crawl around and check everything electrical. Make sure your fuse box is clean, no water residue inside. Your battery should say 12 volts when the car is off and 13 to 14 when running, meaning the alternator is charging the battery. But check the voltage when you start the car and see if the voltage dips below 9, that means the battery is getting weak. I really think its a rogue wire somewhere.
Old Jun 12, 2022 | 02:19 PM
Jman1234's Avatar
Thanks JTBell I'll continue looking and see what I can find.
Old Jun 14, 2022 | 08:58 AM
The belt could be slipping. I've also had a new alternator be bad right out of the box before, so don't rule that out. Certainly check for corrosion on your battery cables, alternator cables, and fuses.
Red Monte Carlo
Jun 30, 2014 10:10 AM
armetta60
Aug 8, 2013 08:42 AM
twinswin91
Feb 2, 2013 10:08 AM
bhines47
Jun 19, 2012 08:57 PM
Duderino
May 30, 2011 05:17 PM
