2006 LT - E-Brake pedal goes to floor
Old Oct 12, 2011 | 09:12 AM
06LT's Avatar
Default 2006 LT - E-Brake pedal goes to floor
I'm not too familiar with the e-brake setup on the Monte; the pedal goes to the floor when pressed, and the e-brake doesn't hold. Do the parking brake shoes need to be replaced, or does the rear cable just need to be adjusted? I'm doing the rear pads and rotors later today, so I'll have a better idea as to what the shoes look like, but I just wanted to get some info from you guys.
Thanks!
Car has 113,xxx kms
Old Oct 12, 2011 | 01:11 PM
JaxJim's Avatar
I'm guessing that the e-brake is cable operated. If it used to work and now goes to the floor, it could be a cable failure. I'd start by checking the cable and all the connections.
Old Oct 31, 2011 | 12:04 AM
shovelhead pete's Avatar
I'm having the same problem...I swear I've seen a parking brake adjusting tutorial on this site somewhere, but for the life of me can't find it again. Can anyone point us in the right direction?
Old Oct 31, 2011 | 12:08 AM
i would also check the cable.
it doesn't engage at all?
Hasnolimits
Jul 19, 2012 05:09 AM
couch
Oct 19, 2007 10:03 PM
motoguy1012
Jun 24, 2007 07:41 PM
mghtymonte
Jul 30, 2004 03:23 PM
