2006 interior teardown questions
Old Feb 25, 2010 | 08:09 AM
chaleyss's Avatar
Default 2006 interior teardown questions
im trying to redo the system and i am wondering how to remove the door panels,seats, back seat, and center console, and the rear deck were the 6x9's are at. thanks for the help in advanced
Old Feb 25, 2010 | 11:58 AM
skylark65's Avatar
it would probibly be a good investment to pick up a haynes manuel for starters, it can tell you where alot of the fasteners are. another thing to remember about these cars is that they are all assembeled in a similar fashion. even on the 5th gen cars many interior panels are held on using the same basic methods as 6th gen and 7th gen cars. check out the "how to" section of this forum, im sure you can find something to help you out over there in one of the sections. and good luck getting everything togeather
Old Feb 25, 2010 | 06:02 PM
chaleyss's Avatar
thanks. usually it is about the same from generation to generation. but im scared of the sudden changes from the model year and everything
Old Mar 1, 2010 | 07:21 AM
bonang's Avatar
Rear Seat:
There is a trim panel that shows the Baby seat logo. That pulls out. Its held in with studs that have threads(no nuts) I broke mine but you cant tell. It pulls straight up. When that is removed. You will see two 18mm(If I remember correctly) Bolts on the right and left side. They hold in the seat bottom. There is a Nut in the center but we will get to later. Remove the two left and right bolts. Pull the front of the seat straight up toward the headliner. It will pop up. Then the seat bottom will come right out.
Now the seat back. Remove the seat belt bolts and the center nut. (18mm think). Its 18 or 16 I forget off hand. Fold the seats down and you will see four 10mm bolts on the two on each side of the seat latch. Remove them. Once removed. take the seat belts and move them to the rear deck lid just to get them out of your way. It is best to have two people to do this part here. Pick the seat up to the head liner and re move it from the studs and clear from the rear of the car and take out the passenger side of the car (seat slides eaiser)
The rear deck lid is easy to get out. There are 4 or 5 push locks, just pop them out the deck lid pulls toward the front the car. Be carful as well this is only thin wood(particale board).
Pics below of what mine looked like witout the seat installed.
Old Mar 1, 2010 | 09:52 AM
monte07's Avatar
my question is why would you remove the back seat just to replace the 6x9 in the rear? is it because of how every thing is tied together or some thing different
Old Mar 2, 2010 | 06:17 PM
chaleyss's Avatar
how did you take out the bottom part of the seat??? did it pull up??? or is there screws. i dont think that i would need to take out the back support on the backseat do i??
Old Mar 15, 2010 | 10:12 AM
bonang's Avatar
Sorry for the delay. Yeah The whole rear seat has to come out to remove the rear dash cover to install new speakers.
The front of the rear seat is held in by pressure no bolts or screws. SHould be able to leaft up the front toward the headliner. It will be hard but it does go.
Old Mar 15, 2010 | 04:13 PM
mak330's Avatar
i think he ran better speaker wire, from his HU. thats smart and what i did even to the doors too. stock wire is super small and isnt to be trusted. great pics. i dynomated from under the rear seat to the trunk lid, doors, headliner[right in the middle above the mirror], and glove box.
personally if you do the work to take it all out you might as well slap some aluminum covered tar in there. lol
DTG
Jan 4, 2012 03:12 PM
DTG
Dec 30, 2011 06:12 PM
my00monte
May 26, 2011 03:40 PM
peno67
Jan 9, 2011 10:29 AM
cheri
Oct 25, 2010 03:16 AM
