2004 monte carlo rpm jumping and stalling
Old Jan 3, 2015 | 08:18 PM
bloodwolf6227's Avatar
Default 2004 monte carlo rpm jumping and stalling
Hi everyone so my car had been acting weird for about 2 months when i have my car stopped or in park, once my car warms up the rpm's will idle at around 700 but it will drop to about 400 then it will jump up to about 1,200 and lately it's been stalling more and more. When I'm driving it will do it randomly and it will feel like a giant thud but then it's fine for a little while but then it will do it again and I've tried cleaning the mass air flow senser and nothing. PLEASE HELP
Old Jan 3, 2015 | 09:28 PM
1st,
How's the fuel pressure at the fuel rail?
Could be a failing fuel pump issue.
Whens the last time it had the fuel filter replaced?
Is it full of oil? when was the last time it had an oil change?
Have you tried un pluging the MAF and see if it runs better and or doesn't stall out? If the runability is better... I would replace the MAF... Is the Maf an AC Delco? If it isn't That could also be the problem. Its highly recommended to use only ACDelco products when it comes to MAF replacement as any other brands cause such problems your experiencing!
Hope this helps as I'm sure others will chime in with more answers to resolve this issue.
Thanks for joining the MCF Family..
Keep us informed as to what the problem was and what the fix is.
As it could be useful to help others that may run into the same issue/problem!
Old Jan 3, 2015 | 09:43 PM
The oil if fine I changed the oil and oil filter not too long ago. I will check the fuel pressure and the fuel filter and let y'all know thanks for the advice
Old Jan 3, 2015 | 09:47 PM
Your quite welcome!
How long have you owned this Monte?
Did it come with any maintenance records? Usually that's a good indicator of how your Monte has been taken care of...
Keep us posted of your progress Tks!
Old Jan 4, 2015 | 08:05 AM
JC Colon's Avatar
I had the same problem twice. The first time it was due to a non AC/DELCO MAF. Once I discovered that was the problem I put the old one back in. 4 months later the old one became highly sensitive to Heat in the cold. When the engine reached N.O.T. The engine would shut off and would not start again until the engine temp went down below N.O.T..
This happened on the 20 mile trip home and as a Blizzard started. I put in a new MAF, and I haven't had this problem in a year.
Old Jan 4, 2015 | 09:28 AM
03vaderSS's Avatar
Wow I'm having the same issue too I mean mine is highly modded and I'm running a fairly big cam and currently with my stock converter it has to idle at 1100 warm otherwise it will shut off but It does go down to like 750 and rev up to 1500 sometimes and especially when it's cold. The lights dim and sometimes it shuts off. When I slow down to lights it drops down to 750is and hesitates than when I completely stop it revs itself back on. I'm pretty sure I need a better converter and maybe a voltage booster. Also when I'm just cruising sometimes I feel the car somewhat hesitating maybe because the converter is trying to pull the Rpms down. But anyway I'm in the same boat as you
Old Oct 22, 2019 | 01:13 PM
EricNKym Justice's Avatar
Default Yo!!!
What tha TuNk does MAF stand for and what us it?
Originally Posted by STUMPMI
1st,
Old Oct 22, 2019 | 01:15 PM
Default Yo yo yo!!
What tha TuNk does MAF stand for and what is it, what does it do, how much is tha cost? Thnks, ya Mother-TuNkers
Old Oct 27, 2019 | 08:47 AM
Jeffs02rwdSS's Avatar
MAF is Mass Air Flow sensor. As for the cost, call the local parts store. Good luck.
ucantseeme702
Oct 3, 2017 03:17 PM
dsanford3198
May 8, 2015 12:18 PM
jrok1310
Feb 5, 2015 11:07 PM
fullmonte2001
Mar 30, 2014 07:50 AM
Skittlez87
Jan 21, 2014 09:56 PM
