2004 Monte Carlo help
Old Jan 25, 2023 | 06:48 PM
Cam's Avatar
Cam
Default 2004 Monte Carlo help
doesn't start unless I press the gas pedal. the other problem I have is that sometimes when my car is coasting to a stop or to make a turn the engine dies. New ignition coils new spark plugs and wires cleaned the maf. Added sea foam to the tank the rpm still fluctuating no check engine light and no codes
Old Jan 26, 2023 | 08:03 AM
nitehawkjcb's Avatar
Might be a problem with the MAF sensor
Old Jan 26, 2023 | 08:05 AM
First thing that comes to mind is the IAC valve. Sounds like its not opening enough to let air in to idle so opening the throttle blade is making up for that.
Old Jan 26, 2023 | 08:34 AM
Cam's Avatar
Cam
Don’t really know how to reply hope I’m doing it right but I just had that changed it stops it from dying now but the rpm still fluctuating and it feel like it be trying to die
Old Jan 26, 2023 | 08:35 AM
Cam's Avatar
Cam
just had it cleaned out
Old Jan 26, 2023 | 09:52 AM
MAP maybe? Most of the time, cleaning the MAF will fix it but sometimes its just faulty and needs to be replaced.
Old Jan 26, 2023 | 10:23 AM
Cam's Avatar
Cam
I’ll have it checked but I just had the maf cleaned
Old Jan 26, 2023 | 10:33 AM
Which engine is this for? My 2nd reply was stating MAP (manifold absolute pressure) sensor. As for the MAF, is it an ACdelco brand?
With the car idling, unplug the MAF and see if it runs better. If it wont idle, unplug the MAF THEN try to start it. See if that helps for the moment.
Does the engine have any visible fluid leaks and have you checked for any vac leaks?
Old Jan 26, 2023 | 12:04 PM
Cam's Avatar
Cam
3.4 and it has a evap leak
Dboybakr
Nov 25, 2017 11:37 AM
N_robertson
Sep 28, 2017 10:39 PM
MartySwillis509
Apr 21, 2016 10:46 AM
gfooce85
Aug 12, 2015 02:47 PM
silver86
Dec 25, 2011 11:59 AM
