Need Some Help!
Old Sep 28, 2017 | 10:39 PM
N_robertson's Avatar
Exclamation Need Some Help!
Hey everyone I'm new to the forum. I have a 2004 Monte Carlo 3.4 that won't run. It cranks and sounds like it's going to start then it stalls. I siphoned out all the old gas and put fresh gas in but is still doing the same thing. I've already replaced the battery, fuel pump, fuel filter, fuel pressure regulator, spark plugs, spark plug wires as well as the ignition switch and ignition lock cylinder. The security light is illuminated on the dash switching between that and the battery sign (both lights are illuminated, not blinking tho). Additionally, the check engine light isn't on. Tried brake cleaner in the intake and the car ran strong for about a second and a half before it stalled out. I have also tried unplugging the MAF and MAP (at separate times) but to no prevail. Any suggestions would be appreciated. Thanks.
