2004 Monte carlo-Can't enable Vehicle Personalization Programming Mode
Old Jul 7, 2014 | 02:15 AM
BigEd's Avatar
Default 2004 Monte carlo-Can't enable Vehicle Personalization Programming Mode
OK today i read through the Owners Manual. In section 2-42 page for "Vehicle Personalization", theres an option for the LT DELAY { Delayed Headlamp Illumination}
This feature allows the vehicle's headlamps and parking lamps to stay on for a fixed amount of time after you exit the vehicle, or for them to turn off immediately.
can be set to 3 possible settings. Mode 1 OFF. Mode 2 30seconds delay , Mode 3 60seconds delay.
But before you can do that, you need to enter the Programming Mode , through the radio , so i attempted to follow the instructions as follows:
To reset or customize the features, first enter the vehicle customization main menu. To enter the main menu do the following:
Step 1 Turn Ignition to ACC or ON position, radio must be off.
Step 2 Press and hold the TUNE/DISPLAY **** for at least five seconds until SETTINGS is displayed.
** I tried that and it doesn't respond. Any ideas on whats up with that and what has to be done so i get into the programming mode? Any help would be greatly appreciated. Thanks .
Old Jul 8, 2014 | 06:55 PM
The Dad's Avatar
I've had to hold mine for 10 or more seconds.
Old Jul 9, 2014 | 08:51 PM
BigEd's Avatar
Ok i will try that. Thanks.
Old Jul 11, 2014 | 03:22 AM
BigEd's Avatar
Thank you, i held for a bit more than 10 seconds and i was able to access the settings function. Your help is greatly appreciated.
Sidestreet
Jun 13, 2015 04:19 PM
Shondu
Jun 1, 2013 03:02 PM
Shondu
Nov 24, 2012 11:01 AM
Cloud_Master
Mar 24, 2008 11:13 PM
