2003 monte carlo ss 3.8 n/a
Old Nov 19, 2014 | 06:33 PM
Toyotapartsguy's Avatar
Default 2003 monte carlo ss 3.8 n/a
I have a 2003 Monte Carlo SS, and have run into a problem. I was driving to work, and it just died. Will crank, but no start. I had it towed to a dealership locally. They diagnosed a bad fuel pump. Had one put in, still no start. Said the ICM tested bad. Took them the one I had changed out about 6 months ago. Tested fine, still no start. Any ideas? Is this place just throwing darts at the problem? The last I heard from them they were checking the crank sensor. Could this FINALLY solve the problem? Any other suggestions I can pass on to them since they can't seem to figure it out would be helpful. Thanks!
Old Nov 20, 2014 | 07:21 AM
My first thought would be a Crank Sensor..
Old Nov 20, 2014 | 11:32 AM
Ok, here is the update. Dealer finally looked at the crank sensor and found a damaged wire. Replaced the wire, and now the car runs fine. Thanks for the help!
ACrazy1rishman
May 5, 2008 07:13 AM
MonteSS03
Oct 10, 2007 12:09 AM
boakesb
Jun 19, 2007 03:29 PM
breman
Sep 27, 2006 09:01 PM
strongasanoxx
May 9, 2006 11:13 PM
