2003 monte carlo ls AC issues
Old Aug 1, 2015 | 08:45 PM
KCFITZ78's Avatar
When you recharge your AC you are to have the car running, AC on, set to coldest setting and fan on high. You do the same for checking the pressure. The max pressure is dependent on the current outside temperature, so you have to refer to a chart that should be provided with the recharge kit.
Before you start, always verify the compressor is working by looking to see if the compressor pulley is rotating.
Also it is a good idea to add AC Oil if you have never had your system serviced to insure the system is lubed
Here is an AutoZone recharge instruction guide ---> Recharging the A/C System - AutoZone.com
Here is another AutoZone AC guide ---> http://www.autozone.com/landing/page...=auto-ac-guide
Old Aug 2, 2015 | 05:05 PM
Jon T's Avatar
added more freon, got a little colder, not much. sprayed down the condenser and my ac works! the cooling fan wont turn on still for the ac but i will check the relays, one is probably bad. thanks everyone!
Old Sep 29, 2018 | 09:44 PM
khel72's Avatar
Its been awhile but did you ever figure out the fans not kicking on with ac? I'm having all the same issues and cannot figure out the problem. Thanks
Old Oct 4, 2018 | 03:24 PM
steven-taylor's Avatar
Need to charge at system of "monte carlo" frequently. Which is very much unexpected! manufacturer should keep concentration closely in that issue. as it's not time convenient for us.
Dboybakr
Mar 13, 2018 09:20 PM
Scollin
Apr 24, 2017 11:24 AM
1996Monte_Carlo
Jun 17, 2011 02:05 PM
saab340
May 27, 2011 08:51 AM
Brembo
Aug 22, 2010 04:07 PM
