2003 3.8
Here's the update, he ended up swapping out MAF disconnected the battery overnight and the problem was solved. His also commented it seemed to have more power now, he always said my car had more power and complained because mine has twice the mileage (268,000 ). I wish you luck wht02monte
BUT, you say there hasnt been any light to indicate the MAF? No codes or anyhting??
When I first looked at the car there was no check engine light .My OTC code reader doesn't show misfire data so I was leaning towards the ICM after we swapped out one of the coils that seemed weak when checking so we changed out with no results. I remember seeing a post about random misfire what brought me to the MAF where ChibiBlackSheep made some comments on. I kinda remember your post about tuning and power loss wish I knew more to help you. Minus the MAF or a plugged catalystic converter I wouldn't know where else too point you as you have swapped out the MAF already and imagine you have done a back pressure test on the cat.
BUT, if the problem comes back.. Be sure to post.. Thanks..
