6th Gen ('00-'05): 2002 Monte Carlo ss transmission replacement
Old Apr 23, 2024 | 05:50 AM
j04rj's Avatar
Question 2002 Monte Carlo ss transmission replacement
For a little background knowledge my car has 238,000 miles. A while back my transmission started slipping and I did the typical fluid flush and filter replacement and it still slipped so I took it into a shop and they quoted me $2300 which I'm assuming covers a brand new transmission plus labor lmao. Im 19 and broke so I'm thinking another route. I contacted a guy off of Facebook marketplace for a 4t65e transmission with 90k miles. I am planning on doing the swap myself but I can't really find any guides that actually helped me understand. I want to replace the transmission without pulling the entire engine out, if possible. I've read that I can use an engine support from the top and drop the cradle and transmission that way, I was wondering which way you think would be easiest or most efficient. I don't wanna accidentally mess something up. Thanks.
Old Apr 23, 2024 | 07:11 AM
I've not come across any good guides for bottom removal lately. Clubgp used to have one, but its long since deactivated (and searching it via wayback is a pain). Service manual may have info on it, but not sure if the procedure details removal from top or bottom.
My only caution is the used transmission. They aren't 100% compatible across years and models, so Id double check the vehicle its coming from is a direct swap with yours.
Old Apr 23, 2024 | 07:17 AM
j04rj's Avatar
The used transmission says it fits the 98-05 impala Buick regal Pontiac on a 3.8 3800 engine, which my car has. Will this fit ?
Old Apr 23, 2024 | 08:19 AM
Not enough info in the generic interchange notes.
For example since you mention the Regal, a transmission for a 2000 regal ls with a 3800 is not a drop in replacement for a 2000 regal gs with a 3800 / nor your car. Another example are cooler fittings. The 97-00 stuff generally used threaded fittings whereas 00+ was generally quick connect.
What is the actual year/model/trim the transmission is out of?
Old Apr 23, 2024 | 01:58 PM
j04rj's Avatar
2000 buick regal .
bjginbc
May 19, 2023 10:13 PM
Butwhat
Apr 18, 2022 03:38 PM
bigboy79
Jul 6, 2016 09:05 PM
Nawxgh
May 7, 2012 02:33 AM
bat208
Oct 28, 2011 02:45 PM
