2002 monte carlo engine swap?
Old Oct 24, 2011 | 02:52 PM
bat208's Avatar
Default 2002 monte carlo engine swap?
so i bought a 2002 monte carlo for just over 2k. it has over 350,000k on the motor so does anyone know what engine rebuild prices or crate engine prices would cost me?
Old Oct 24, 2011 | 05:27 PM
U can get a used one from a salvage yard, usually a good low milage one will run close to a grand or so depending on the yard
Old Oct 27, 2011 | 04:32 PM
jasonsmith's Avatar
Is that original miles? Or had the engine had previous work done?
Old Oct 28, 2011 | 09:33 AM
bat208's Avatar
that is original
Old Oct 28, 2011 | 10:13 AM
why not do a top swap or swap out for an L67, you could bite the bullet and just go all the way for the 5.3L swap which will be a ton of work.
200k miles isn't a ton for those 3800 series II's I could see you doing a top swap, check some of the bottom end make sure everythings good with the current engine.
The lower compression will make you some more power than just an L67
Old Oct 28, 2011 | 10:24 AM
drive it 'til it goes, then grab a junkyard engine and swap it.
Old Oct 28, 2011 | 02:19 PM
Enzo354's Avatar
STILL SLOW
Yea, who doesn't throw boost at a 350k motor.
Old Oct 28, 2011 | 02:26 PM
that's only around 217,000 miles, not a ton more than chibi and he's boosting.
Old Oct 28, 2011 | 02:32 PM
I also know the FULL history of my car, and have a 2nd car because there will most likely be plenty of down time while I break stuff lol
Old Oct 28, 2011 | 02:34 PM
true, how many miles on your car?
