2002 Monte Carlo SS battery replacement.
Old Aug 24, 2007 | 06:47 PM
thorspower's Avatar
Default 2002 Monte Carlo SS battery replacement.
Is there an easy way of doing this? I have never owned a Monte Carlo myself I am trying to replace the battery on my moms Monte Carlo. From the look of it it's not going to be an easy task a lot of stuff in the way and no simple way of just getting to the battery without removing some parts. Any one with some advice would be much appreciated.
Old Aug 24, 2007 | 08:14 PM
2000LS's Avatar
Default RE: 2002 Monte Carlo SS battery replacement.
they like it in their homes, and they really dont seem to want to come out and play... but i belive what i usually do is:
disconnect the battery
remove the brace above it
take off the battery hold down
remove fusebox fasteners
slide the fuse box out and up a couple inches
tip up the battery on end, so that the side at the rear is facing up
lift out the battery
install in reverse
Old Aug 25, 2007 | 07:26 AM
wiz kidd's Avatar
yah, it looks hard, but its not bad
2000ls' instructions cover everything
Old Aug 26, 2007 | 08:58 AM
04 Intimidator's Avatar
You might need to twist the battery around a bit too. I was able to pull mine in about 5 min with tools in hand, but a good chunk of the time was just trying to pull the darn thing out from its place.
Old Aug 26, 2007 | 01:37 PM
2000LS's Avatar
04 intimidator - i figured that was understood, everyone knows its never as simple as the instructions say it is.
cnogood
Sep 20, 2014 04:16 PM
Huckster
Jun 21, 2013 12:14 PM
70monte1
Jun 14, 2012 05:12 AM
BIG AL 070
Jul 20, 2010 09:28 PM
DCfla
Aug 20, 2009 01:26 AM
