2002 Monte Carlo Fuel pump location?
Old Jan 18, 2010 | 09:08 PM
MyMonteSS's Avatar
Default 2002 Monte Carlo Fuel pump location?
Hello everyone. I've got a bad fuel pump to replace and I don't know where it is located. I know it's near the fuel tank but am I gunna have to remove the whole tank? I saw on WIKI answers that somebody said it could be done with taking out the back seat or somethin like that. thanks for any help!
Old Jan 19, 2010 | 12:15 AM
Wilco's Avatar
Negative! You'll need to relieve the pressure from the fuel lines and remove the negative batt lead. You can gain access to the fuel pump through a small access panel on the floor behind the rear seat by taking it out, easy if you can find all the bolts holding it down, rear seat trim panel and trunk liner. Or you can take the tank out, but remember to empty it before you remove it. With either procedure it will take you about the same time to get to the FP.
Old Jan 19, 2010 | 02:56 AM
MyMonteSS's Avatar
Thanks for the reply sir. I went ahead and went taking the back seat out route since I am by myself on this thing and I have allready taken the seats out before while putting in new rear speakers. I got all the way till the hole then deiced to quit since it was late. again I thank you for your help
Old Jan 19, 2010 | 07:18 AM
Wilco's Avatar
No problem! If you have anymore ?s feel free to ask. Someone will have an answer for ya.
Old Jan 20, 2010 | 05:58 AM
kateriyan's Avatar
Hi this is kateriyan here ,
Are you running the tank close to empty? Uses fuel as a coolant for pump
Have you changed the filter sock?
Have you cleaned the tank?
Old Mar 17, 2010 | 03:27 PM
DIGIMURDA's Avatar
how do i relieve the pressure?
Old Mar 18, 2010 | 08:02 PM
MyMonteSS's Avatar
There is a schrader valve (looks like a valve stem kind of.) on your fuel line. Has a blue type screw cap on it. Should be underneath the engine cover if I remember right.
Old Mar 19, 2010 | 09:58 AM
DIGIMURDA's Avatar
hi,
i changed the fuel pump and now my fuel gauge reads a quarter tank more than it actualy has, and sometimes it goes back to where its supposed to be and then back to a quarter more.........did i do something wrong? or did i miss something?
Old Mar 19, 2010 | 01:48 PM
IMO if you go through all the work of buying a new sock and putting it on, you may as well just spend the extra money and stick a new pump in, they're not that bad.
ReaperSS
Aug 29, 2014 11:35 AM
elgato
MCF Website Problems & Issues
Jul 8, 2014 09:41 PM
soaxin
Feb 11, 2014 10:00 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
Monte Mayham
Mar 12, 2010 11:36 AM
