2002 air control problems
Old Sep 1, 2010 | 12:14 PM
weld dr's Avatar
Cool 2002 air control problems
Hi all newbe here.I have a 2002 monte le and the air heat controls are now acting up.The right control works fine but the drivers control won't give me cool air when it's all the way down.When you push it up you get hot.Any help would be great
Old Sep 1, 2010 | 12:25 PM
...Welcome to the Monte Carlo Family.
Sorry to read that you are having a problem with your Monte & I hope one of our expert tech member's reads your thread & can assist...Check back to see if it is answered....
Below are a few links that you may want to check out & see if it gives you some advise or resolve on your problem...Good Luck
p.s. we also would like to see/hear more about your bike : )
WikiAnswers - How do you fix a AC and heater fan speed control ...
Same Issue: However, Speed 1 & 2 are not working on mine. ... Heat & Air Conditioning: Heater & AC Controls :: ACDELCO Part# 1472736 (Control,HTR & A/C 2 Doors; w/A/C FRT MAN/AUX ... Chevy monte carlo heater fan doesn't start to blow right away? ... 2003 monte carlo heater control? 2002 monte carlo ac problem? ...
wiki.answers.com/.../How_do_you_fix_a_AC_and_heater_fan_speed_control_knob_on_a_2002_Monte_Carlo_that_has_stopped_... - Cached - Similar
2002 MANUAL A/C-HEATER SYSTEMS Impala & Monte Carlo | Auto Repair ...
May 26, 2010 ... 2002 MANUAL A/C-HEATER SYSTEMS Impala & Monte Carlo ... 2003 Chevy C 1500 P/U HVAC Module Assembly Replacement ... lanr rover 1995 climate control fans not working, 2002 impala ac refill filler plug, alternator removal ...
www.autozmagz.com/chevrolet/2002-manual-ac-heater-systems-impala-monte-carlo/ - Cached
Old Sep 1, 2010 | 12:29 PM
weld dr's Avatar
Cool
Thank you for your quick response sorry i started this post in the wrong section it will take some time 2 get used 2 this forum.
Unikardo
Oct 21, 2014 09:58 PM
Jul 8, 2012 08:27 AM
Overdose666
Feb 20, 2010 09:24 PM
Crisby
Nov 16, 2008 07:13 AM
adryan16
Feb 29, 2008 04:48 PM
