2001 SS PLEASE HELP!
Old 09-27-2007, 12:48 PM
Default RE: 2001 SS PLEASE HELP!
ORIGINAL: AwsomeSS
I thought I had a battery issue but it turned out that when someone installed my 6 disc CD changer, it was always drawing power from somewhere and that was killing my battery. When I got it rewired, no battery prob any more.
what was the problem with it drawing power. do u know ?
i have had 2 batteries go on me in the last 3 months. i have an aftermaket radio, amps, a cap, and my headlight switch when bad also not sure if any are related but who knows
Old 09-27-2007, 02:46 PM
ORIGINAL: thatrealcreole****
ORIGINAL: AwsomeSS
The problem with AwsomeSS would have been that the power to the CD changer was hooked up to 12v constant and not accessory.
You might want to check the head unit and other wiring to see if you are getting the same issue.
Old 09-28-2007, 06:51 AM
Some tricks I learned from an old school mechanic to check for a dead cell.........however they will only work with a battery with removable caps,which are pretty rare anymore.
1. Remove the caps and shine a flashlight into the holes.A good cell will be crystal clear.A bad cell will look cloudy and milky.
2.Have someone crank the engine while you look into the battery.A bad cell will bubble and boil.under the cranking load.The good cells may bubble a tiny bit,but the bad one will really "cook".
Hope this helps .
Kenneth Mcadams
04-05-2013 03:48 PM
01navyss
10-19-2012 02:25 PM
MJClemm
08-01-2012 12:30 PM
Herlsy
03-12-2012 08:15 AM
TeddyB94
02-10-2010 10:38 AM
Quick Reply: 2001 SS PLEASE HELP!
