2001 Monte Carlo SS Sunroof probleims
Cleaning the tracks and grease them with a light weight grease. This may cure some of the problems. I had to repetedly hit the switch to get mine all the way open but after the greasing it works fine.
I uninstalled my sunroof to see why it won't open or close (once open) and the right arm (passenger side) track system do not move. The left side moves freely with no problem. So I installed the sunroof back and wondering what is the problem. I had to pull and push the arm while stuck when I press the button forward. I don't wanna purchase that $200+ replacement part over a easy fix. If there is one....
JD1979
Nov 3, 2020 07:58 AM
