2001 Monte Carlo engine hesitation
Old Oct 21, 2010 | 12:12 AM
churritos626's Avatar
Exclamation 2001 Monte Carlo engine hesitation
hey, my monte carlo has engine hesitation. i have changed out the spark plugs and spark plug wires. it improved to pick up speed, but still has hesitation.
is there anything else that can cause this? O2 sensor pssibly faulty? coil pack?
thanks
Old Oct 21, 2010 | 10:40 AM
zipper's Avatar
Just out of curiousity, is your Monte an LS or an SS?
Also, could you describe the hesitation a little bit more?
Old Oct 21, 2010 | 11:09 AM
SS when you pus on the gas pedal the rpm stays low and it sounds like its having trouble getting to a higher rpm. it also feels like there is lack of torque cuz when i add more gas theres no difference unless im going downhill.
Old Oct 21, 2010 | 07:47 PM
jim1405's Avatar
My 2001 with the 3.4 had the same symptoms. It acted like it was bogging down on acceleration and would then eventually get up to speed. After a couple hundred miles of this I began to hear a hissing sound when accelerating. Turned out to be a plugged catalytic converter. Upon replacing the car was back to normal. Might be one thing to check.
Old Oct 22, 2010 | 12:38 PM
Nocturnx's Avatar
I was also thinking something wrong with the Cat. How does your air filter look? If your air filter is fine I would assume your Cat is clogged.
Old Oct 22, 2010 | 11:19 PM
nitehawkjcb's Avatar
Sounds like a bad cat or O2 sensor.
Dex21
Sep 4, 2014 01:03 AM
donorlow
Mar 10, 2013 10:14 AM
litaf201
Jun 24, 2012 01:40 PM
6Kwatt06
Feb 22, 2011 11:21 AM
JayteeWilson
Nov 6, 2010 03:05 AM
