2000 Monte Carlo SS idles wont accelerate
Old Jan 26, 2012 | 06:09 PM
powerguy5051's Avatar
Default 2000 Monte Carlo SS idles wont accelerate
drove down the road stopped at a stop sign gave it the gas and it died starts and idles but you touch the accelerator and it dies. anybody every have this and if so what did you do. thanks
Old Jan 26, 2012 | 08:47 PM
The '00 and '01 Montes got a bad batch of Catalytic Converters from GM's supplier, so bad GM extended the warranty (but I think the extended CAT warranty is expired now).
Knowing that, if you still have the factory CAT, might be worth having that checked out.
Old Jan 26, 2012 | 10:01 PM
codell17's Avatar
I agree with The_Maniac, most likely that catalytic converter(s). How many miles are on it? I had a Chevy Astro van with a 4.3 v6 some time back, and it did the same thing. Replaced the catalytic converter, and it was great after that.
Old Jan 26, 2012 | 10:15 PM
Default plugged converter
I definitely will give that a try, Keep you posted on the results. Thanks
Old Jan 26, 2012 | 10:24 PM
codell17's Avatar
One thing you can try is, take out the O2 sensor before the catalytic converter, and it will let the exhaust out of that hole. Try to drive it down the block like that and see if it dies. It should pin-point your problem. Just in case its not the cat, it will same you some time and money (and aggravation!) GOOD LUCK!
Old Feb 9, 2012 | 01:39 PM
MJClemm's Avatar
My car WAS doing the same thing. I replaced the Fuel Filter with no progress, then (I listed to all the MEMBERS at the MCF and had the CATALYTIC converter replaced, RUNS like new... So you can use this as a gauge... They were all right, so....
Old Feb 9, 2012 | 01:54 PM
PacerSS's Avatar
I'm going out on a limb here and since it happened instantly and not over time, I am betting it's a vacuum leak.
Old Feb 9, 2012 | 03:05 PM
Jomao_o's Avatar
MAF or IAC.
Mine had symptoms like yours and it was the MAF.
Old Feb 9, 2012 | 07:05 PM
PacerSS's Avatar
Yeah could be MAF as well. But generally a stock speed density tune would keep it alive. Plus the check engine light would go off.
Old Feb 10, 2012 | 05:46 PM
jwjones's Avatar
I am willing to bet it's a vacuum leak as well. My 96' Grand Am SE would do the exact same thing his is doing. Was a pin size hole in the vacuum. cut the end off and reattached the line and it worked perfectly.
