2000 Monte Carlo Power Windows
Old Jan 25, 2006 | 07:30 PM
te100's Avatar
Default 2000 Monte Carlo Power Windows
The 2 steel cables managed to get tangled in the gear and got all screwed up. Can you buy just the cables or is this a dealer thing?
Old Jan 26, 2006 | 12:38 AM
chevy_jj's Avatar
Default RE: 2000 Monte Carlo Power Windows
what those cable are is your motor regulator. what it does is acts kinda like a garage door, where as the door weighs an ungodly amount but yet due to the springs you can lift it with one finger or lift it with a 3/4 hourse motor because the springs will assist in the lift. same concept here. the window motor will not lift alone so on early power window setups you have a clock spring setup to help lift the window. modern day setup went to a pully system with plastic pulleys and cables. isnt that quite the couple. very common break/proble. you may be able to get the regulator assembly alone. not sure. $$ cost you some money. thank god for tax returns.
Old Jan 28, 2006 | 10:13 AM
te100's Avatar
[&:]I bought a replacement $165. but it is everything(motor, cable, frame). Just unbolt the other slide out and bolt new one in took about 10min.
Old Jan 29, 2006 | 12:56 PM
chevy_jj's Avatar
yeah they are pretty simple. ive done quite a few in my days of wrenching. not too bad for the whole assembly
Old Jan 29, 2006 | 05:31 PM
can2tx's Avatar
Hey the regulators are available through GM Parts Direct. Here are the part numbers & prices:
Drivers side - 10309981 Left side - $85.55
Passenger side - 10309982 Right side - $83.11
They are easy to install, it just takes a Torx, Philips, and I believe 1 or different sized sockets. All together maybe a 20-30 minute job, hardest part is being careful removing door panel and not breaking plastic pins - be careful.
chevymontess
Sep 13, 2011 10:00 PM
hotrodmonte
May 14, 2011 10:01 PM
Buknasty
Jun 18, 2010 08:49 AM
TZ97
Sep 9, 2009 09:36 PM
Cowboy6622
Jan 22, 2008 12:14 PM
