6th Gen ('00-'05): 2000 Monte Carlo/ Body Issues
Old Aug 7, 2014 | 06:32 PM
slimetime214's Avatar
Default 2000 Monte Carlo/ Body Issues
How do i bend my driver car back into place at the top after breaking into it after locking my keys in the car and why is water running into the bottom of the car because my carpet is always wet?
Old Aug 7, 2014 | 07:56 PM
Where are you located ? You open the door an install a 2x4 in the door opening and push on the upper door frame with your hand to bend it back into shape. You should lower the window before you try this..
Old Aug 7, 2014 | 07:59 PM
What side is wet it maybe the water is coming in thru the blower motor the weather seal maybe off.
Old Aug 7, 2014 | 08:02 PM
Its on both sides but really the passenger side bad.
Old Aug 7, 2014 | 09:24 PM
Aaron0313's Avatar
Is it worse when you run the A/C a lot?
Have you cleaned out the evap drain hose under the car with some compressed air?
Old Aug 7, 2014 | 11:29 PM
AC doesn't work just happens when it rains or snows and its hard to get the water out sometimes
Old Aug 8, 2014 | 08:52 AM
DCMoose48's Avatar
Here's the solution for your water problem:
Permanent Cabin Air Filter Water Problem Fix
Old Aug 8, 2014 | 10:17 AM
How Do I Fix That?
Old Oct 19, 2014 | 11:24 PM
el pachuco's Avatar
Thank you very much for posting the link.
How Do I Fix That?
this is a link to another thread that details how to fix your problem. Place your cursor on the above line and click on it.
bucca64
Feb 20, 2014 01:29 PM
mandill
Mar 27, 2013 03:25 AM
el402
Sep 24, 2011 10:58 PM
gdogg090
Jan 31, 2011 03:46 PM
Draciel
Sep 13, 2009 01:25 PM
