2000 Monte Carlo
Old Jul 4, 2016 | 01:16 PM
Solomon Stroup's Avatar
Default 2000 Monte Carlo
I have an issue with the steering wheel controls. I have no wipers and no steering wheel controls. I do have turn signals, horn, and washer motor working. I have changed out the turn signal switch. Issues still persist. Fuses are ok. I do have an airbag light on, so I'm wondering if it is the clock spring. is there a way to test the clock spring in these cars?
Thank you in advance.
Old Jul 4, 2016 | 04:12 PM
Sounds like odds are high it's the clockspring for the air bag light, horn and the wheel controls. Not sure this plays into the wipers. Get a good scan tool that can read codes other then the PCM (might require a GM Tech II scan tool) to read the air bag trouble code.
Another possible method, disconnect the clock spring at all ends and try doing a continuity test across the pins.
