2000 Monte carlo
Old Aug 6, 2014 | 01:08 AM
hillbillywizard's Avatar
Default 2000 Monte carlo
Started the car today, and noticed the fan for the climate control only worked on speed 5. Blower control module is behind the blower motor? Am I correct?
Thank You.
Old Aug 6, 2014 | 10:27 AM
DCMoose48's Avatar
Yes... you will have to go up under the dashboard and remove the blower to get at it. I assume that the water leaking in from where the cabin air filter is fried my blower motor resistor so I would suggest doing the fix for that first if you haven't already (the part was only $6 at my local dealer - credit to Chibi for posting that fix). Rock Auto has the resistor for $28.79 vs. over $80 at my dealer.
Old Aug 6, 2014 | 05:59 PM
Aaron0313's Avatar
Here's a video:
It's really similar to the Impala so it should be helpful
Old Aug 7, 2014 | 05:09 AM
Habbibie's Avatar
On the right side fuse panel inside the car there is a fuse that's marked hvac it's a 25 amp fuse that one has blown on you. Replace it with a new one and the remainder of your fan speeds will work again. I'm 100% sure of this. Don't replace your module not your resistor.
billyp35
Feb 1, 2007 08:00 PM
TGAbreu
Dec 9, 2006 10:31 PM
Mike
Aug 29, 2006 10:33 PM
00pacecar
Jul 6, 2006 02:18 AM
te100
Jan 29, 2006 05:31 PM
