2000 buick le Sabre
Old May 27, 2010 | 06:54 PM
kweef's Avatar
Default 2000 buick le Sabre
Just lookin to c if anyone here has any ideas about what could be wrong seeing as how im at a dead end
Car is a 2000 buick le sabre, problem is inop drivers front window. I unplugged motor and tested the wires with my dvom and got 12 volts both ways when pressing switch so i ordered a new motor. got the new motor and installed it and the window is still inop so i tested the motor on passengers front and the motor worked. basically i have power and ground to the motor, a good motor and it still doesnt work. the next thing i did was check my connector to the motor. it is not burned and i removed the pins from the connector to check them and they appear fine. I am at a loss to as what could cause the good motor that has power and ground to be inop. any ideas are welcome.
God_Bot
Aug 27, 2008 09:36 AM
motivation2k3
Aug 10, 2008 11:58 AM
Bigg J
Jun 20, 2007 06:56 PM
monte83
Aug 26, 2006 09:57 PM
