1st Gen Lighting Issue
Turn signal indicators light up when headlamp switch is turned on and stay lit on until the switch is turned off. All exterior lighting works and there are no bulbs out. Four way flashers, turn signal, high-beams, and marker lamps all appear to be fine. What am I missing?
JMiles
70 Monte Carlo
JMiles
70 Monte Carlo
Also check that the bulbs are in the right way. Sometimes when the sockets will wear out and the bulbs will go in backwards. You may want to replace the sockets with new ones if they are worn.
Cream03Luxury
02-22-2012 07:01 PM
