1st Gen Lighting Issue
Old Mar 28, 2012 | 08:18 PM
JMiles's Avatar
Default 1st Gen Lighting Issue
Turn signal indicators light up when headlamp switch is turned on and stay lit on until the switch is turned off. All exterior lighting works and there are no bulbs out. Four way flashers, turn signal, high-beams, and marker lamps all appear to be fine. What am I missing?
JMiles
70 Monte Carlo
Old Mar 28, 2012 | 09:32 PM
You have a bad turn signal bulb, take them all out and put new ones in all sockets, buld size is 1157........Pretty cheap fix in most cases.......
Old Mar 28, 2012 | 10:52 PM
Also check that the bulbs are in the right way. Sometimes when the sockets will wear out and the bulbs will go in backwards. You may want to replace the sockets with new ones if they are worn.
Jparks
May 5, 2012 06:11 PM
kevinoriega
Feb 26, 2012 11:17 PM
Cream03Luxury
Feb 22, 2012 07:01 PM
79Monte
Jan 16, 2007 10:01 PM
