1999 Monte Carlo Z34 3800 series ll spark plug change success!
Old Feb 6, 2016 | 11:38 AM
Anthony Chico Hodge's Avatar
Thumbs up 1999 Monte Carlo Z34 3800 series ll spark plug change success!
I was trying to figure out an easy way to change my back 3 spark plugs, of course the front 3 were easy.
I heard all the suggestions for it and realize that if I remove the nut (s) off the wiring harness on the firewall, it's worth a try.
I had a time removing the original ( I think) wires from the plugs but once I did ,it was a lot easier to change them out. It takes a little bit of time but I did it in under an hour. A word of advice....
Patience and anti-sieze before you install the new plugs.
Thanks for reading!
Old Feb 6, 2016 | 11:47 AM
Thumbs up Congrat's
Thanks Anthony for posting/sharing
How long did it take ?
Old Feb 6, 2016 | 02:30 PM
You're welcome!
It was a beast getting the old plug wires off but unbolting the wiring harness/clips from the firewall and slightly moving the hose to the heating core from the position to be able to reach behind the engine, took less than 20 minutes.
Pulling the old plug wires off the back of the engine took at least 40 minutes. I went about it slowly to not damage anything and create a bigger job/ bill.
The front were easier with no issues.
Total job was actually 1 hr and 30 minutes rounded up....
Old Feb 6, 2016 | 03:28 PM
Thumbs up It's good 2 know how 2 do it yourself & Save Big $'s
Hi Anthony & thanks for your reply
What do you or member's think it would have cost `if you took it to a Chevy Dealer to have it done ?
Old Feb 6, 2016 | 04:17 PM
$125.00-$140.00
I'm no mechanic but I wanted to save money and not get raked over the coals.
I'm glad to be a part of this site and my next job will be replacing a radiator and moonroof motor on my Monte Carlo Z34.
It's nice to read and find help.
Last edited by Anthony Chico Hodge; Feb 21, 2016 at 10:45 AM. Reason: not finished
