1997 brake issue, which switch?
Old Jul 16, 2012 | 10:11 PM
Val1970's Avatar
Default 1997 brake issue, which switch?
I have read and found the problem but confused as to which switch needs replacing. 3rd brake light works, other 2 do not work unless you toggle the signal arm.
So is it the multifunction switch that needs replacing? Is that the only part it could be? Is this the part that includes the arm, controls for cruise control, turn signals etc? Where can I buy this part online?
Old Jul 16, 2012 | 10:31 PM
most likely the multi switch, do you have an auto parts store nearby... Advance Auto, Napa etc......or you can get it online.
Old Jul 16, 2012 | 10:50 PM
Val1970's Avatar
We are somewhat limited on auto parts stores. So I have been searching online. But havent been able to find the right one for my car. Anyone have a link or parts number?
Old Jul 16, 2012 | 11:01 PM
LS or Z34 model?
Old Jul 16, 2012 | 11:04 PM
Val1970's Avatar
LS or Z34 model?
It is the LS
Old Jul 16, 2012 | 11:08 PM
it should be one of these from Napa online? With or without steering wheel audio controls..... I hope that helps....
Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl06$ hdnTextDetail value=MPEDL6316SB_0372643061 type=hidden>Part Number: MPE DL6316SB
Product Line: Mileage Plus Electrical
IMPORTANT INFO: w/o Steering Wheel Audio Controls
<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl06$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_c hkCompare>Add to Compare</LABEL>
<LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_c hkCompare></LABEL>
Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl07$ hdnTextDetail value=ECHDL6316_0372643071 type=hidden>Part Number: ECH DL6316
Product Line: Echlin Ignition Parts
<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl07$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_c hkCompare>Add to Compare</LABEL>
<LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_c hkCompare></LABEL>
Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl08$ hdnTextDetail value=ECHDL6315_0372643070 type=hidden>Part Number: ECH DL6315
IMPORTANT INFO: w/ Steering Wheel Audio Controls
<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl08$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_c hkCompare>Add to Compare</LABEL>
</LABEL>
</LABEL>
Old Jul 16, 2012 | 11:13 PM
Val1970's Avatar
Thanks! I wasnt sure if this was the part, or the ones I have seen that have the whole lever with it.
jlange101
Aug 25, 2012 05:29 PM
Enos Burdette
Jun 3, 2011 04:15 PM
jeffrae
Dec 21, 2007 04:30 PM
Zackb911
Dec 22, 2006 07:22 PM
Nortybignort
Jul 25, 2006 10:35 PM
