1997 brake issue, which switch?
I have read and found the problem but confused as to which switch needs replacing. 3rd brake light works, other 2 do not work unless you toggle the signal arm.
So is it the multifunction switch that needs replacing? Is that the only part it could be? Is this the part that includes the arm, controls for cruise control, turn signals etc? Where can I buy this part online? |
most likely the multi switch, do you have an auto parts store nearby... Advance Auto, Napa etc......or you can get it online.
(Post 478426)
LS or Z34 model?
(Post 478439)
LS or Z34 model?
it should be one of these from Napa online? With or without steering wheel audio controls..... I hope that helps....
http://partimages.genpt.com/thumbs/396201.jpghttp://partimages.genpt.com/partimages/1148655.gif Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl06$ hdnTextDetail value=MPEDL6316SB_0372643061 type=hidden>Part Number: MPE DL6316SB Product Line: Mileage Plus Electrical IMPORTANT INFO: w/o Steering Wheel Audio Controls <INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl06$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_c hkCompare>Add to Compare</LABEL> <LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_c hkCompare></LABEL> <LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl06_c hkCompare>http://partimages.genpt.com/thumbs/274599.jpghttp://partimages.genpt.com/partimages/1148621.gif Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl07$ hdnTextDetail value=ECHDL6316_0372643071 type=hidden>Part Number: ECH DL6316 Product Line: Echlin Ignition Parts IMPORTANT INFO: w/o Steering Wheel Audio Controls <INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl07$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_c hkCompare>Add to Compare</LABEL> <LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_c hkCompare></LABEL> <LABEL class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl07_c hkCompare>http://partimages.genpt.com/thumbs/274598.jpghttp://partimages.genpt.com/partimages/1148621.gif Turn Signal Switch<INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_hd nTextDetail name=ctl00$ContentPlaceHolder1$rptrProducts$ctl08$ hdnTextDetail value=ECHDL6315_0372643070 type=hidden>Part Number: ECH DL6315 Product Line: Echlin Ignition Parts IMPORTANT INFO: w/ Steering Wheel Audio Controls <INPUT id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_ch kCompare name=ctl00$ContentPlaceHolder1$rptrProducts$ctl08$ chkCompare type=checkbox><LABEL id=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_lb lCompare class=lblCompare for=ctl00_ContentPlaceHolder1_rptrProducts_ctl08_c hkCompare>Add to Compare</LABEL> </LABEL> </LABEL> |
(Post 478442)
