1985 monte ss right turn signal on when lights are on and buzzin
Old Dec 7, 2006 | 11:42 PM
djizzle's Avatar
Default 1985 monte ss right turn signal on when lights are on and buzzin
hey. i started my car just now. i just got it. well i started it anfd then turned ont he lights. well the righ turn signal is on and its buzzing...its an 85 monte ss....let me kno please.....thankz everyone...
Old Dec 9, 2006 | 01:31 AM
RippedMantis's Avatar
Default RE: 1985 monte ss right turn signal on when lights are on and buzzin
My blinkers were messed up on my '86 LS when I got it. It was before I started tinkering with cars, so I don't know exactly what my dad did to fix it. I'm guessing on this, but I think there was is a multifunction switch in the steering column that needed replacement. Also, that lil blinker can is cheap to replace to eliminate a possability.
Old Dec 11, 2006 | 02:33 PM
firebird_1252's Avatar
before you start pulling the colum apart i'd start with the easyest first. swap the flasher out.
Old Dec 15, 2006 | 11:58 PM
steptoe's Avatar
If a turn signal or hazard flasher won't stop the problem then I would check front and rear parking and tail lights for a bad ground or short. (I had a bad light socket in my left rear tail light of my '86 Monte.) If that doesn't work, put a new turn signal switch in the steering column.
Old Jan 19, 2007 | 01:05 PM
solosociety's Avatar
i had the same thing happen to me in my 83 ss but my steering column had caught fire just before that. it ended up beiong a short in the wires.
Redline29
Mar 30, 2019 03:46 AM
crazyzach722
May 22, 2014 12:20 PM
taz7nads
Jul 19, 2012 09:38 PM
Ndizzle428
Mar 17, 2010 04:07 PM
Plengr
Oct 23, 2009 08:47 AM
